billyray50
May 16, 2017Explorer
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29276177/gotomsg/29280870.cfm#29280870
I just installed uppers April 30th on my 2015 Ram DRW. Make sure you spray original factory bump stops bolts to help loosen before removal. The hardest part was the custom longhorn Laramie wheel liner inserts. Had to remove them to gain easier access for stable loads. I permanently trimmed liners too for future access. Also for my truck year/model you have to cut or grind off one anti rotational tab to be able to install them. The Torklift bolts are a lot longer than factory so you will need deep socket. I will say Torklift stable loads made a big difference and improvement in a little squat in rear and also in handling.
