Bedlam
May 17, 2017Moderator
If that is all the clearance between the overload spring and pad when empty, the Energy Suspension pads would be a better fit height. They compress to about half the height of a StableLoad before engaging the spring tension. If the camper is never offloaded from the truck, the StableLoads would be fine. Running an empty truck with the overloads engaged would discourage you from repeating that drive.
