okan-star
May 17, 2017Explorer
Like I said ,I have no need or want to put those on my 99 Dodge but my upper overload brackets are different than the ones you have , there vulcanized rubber that's flat w/ angled at both ends , I`ve read here that guys have left on the rubber and drilled thru - I believe they said there was a hole in the metal
I would bet Dodge didn't change the holes in the frame , maybe you could go to a yard and find some brackets off a 99- 02
Or cut the rubber off yours and weld a flat on yours
Have you called Torklift ,that would have been the first thing I would have done , they should fit , they cost like 350.00 don't they ?
For that you could buy new rear leafs
