Boatycall's avatar
Boatycall
Torklift Wobble Stoppers....You gotta try these things.
So, came back from a 10-day trip last week, just been busy with work and home stuff to write this up, but thought I would share this.
I usually don't bother taking the TC o the truck on short trips, but on longer trips I do. In this case, 10 days on the Or-E-Gun coast, took it off.
I got these Torklift Wobblestoppers last year, but can't say enough about these things if you take your TC off. Before these things, I would bring short collapsible saw-horses to help stabilize when off-truck camping. These things make the TC rock-solid--even on my big heavy TC.
  • You may just have saved me alot of money......I have been pondering this for the past several weeks.
    My main concern is the Fast gun spring may be stiffer than the wobble stopper. Other than that its a bracket issue.
  • Look at 'em.
    A fast gun w/a clevis type hook on one end.
    Not a problem
  • finsruskw wrote:
    Looks to me like if you made a few mods here and there one could use your fastgubs for the same purpose, providing you had them to begin with.
    At first glance, that's what the W/s'ers seem to be, a glorified version of f/guns!
    I suspect the WS'ers are a bit more than FastGuns. The FastGuns merely pull to anchor points. The WS'ers are designed to limit movement in both push and pull directions.
  • Looks to me like if you made a few mods here and there one could use your fastgubs for the same purpose, providing you had them to begin with.
  • I use short horses also. I'd like to have wobble stoppers , but I'd rather not drill into my TC seeing it's fiberglass.
