JCinAK wrote:
I installed the Happy Jacks on my F250 Short Bed and they work great, they go through the bed but also an L bracket that goes down to the frame so very strong and don't block the fuel door. My issue is the fast lock tie downs work great on the back to the bumper rings, but the front is so short, I need to cut the threads on my tie down. I also installed the Torklift trailer hitch so I can have the 3' extension, and if I need I can add the tie down to the hitch instead of using the bumper. But I have had several trips including off road here in Alaska and no problems, knock on wood.
Probably too late but TL does make a short version of the Fastguns for bed mounted tie downs as well as the long version for frame mounted a tie downs.
