Kayteg1
Nov 24, 2018Explorer II
HadEnough wrote:Kayteg1 wrote:
I build rear tie-downs myself and it is 1" square tubing you can buy at Home Depot.
Than I used 3" square washer used for house anchoring to weld it on the end and drill 2 holes.
About $10 worth of material.
Now that's a good idea!
Could you expand a little more on how you bolted the flat, end face plate with the holes to the 1" square tubing?
As I said, it needs to be welded, although I could think about bolt-on application.
Original plates have a hole with cut slot. I could never figure out what is the purpose of it.
Bottom line, I put about 10,000 miles with home-made rear tie-downs with no problem.
Front base is what is complicated, but you need just the insert, so even if you don't DIY, any weld shop should fabricate that in minutes.
