SoundGuy
Mar 30, 2015Explorer
luvmydogs wrote:
We researched and looked at so many jacks and then settled on what looked like the best one for the money, a Ram. It looked really nice but then we slid it into position and there is no way we can open the tail gate with it. It does not move or swivel any way, its simply to big and no adjusting will make it work. I've seen others with this problem and thought we chose wisely, but we didnt. Totally bummed!
SoundGuy wrote:
Did I not suggest in your other thread that you seriously consider an electric tongue jack on which the head can be rotated, even mentioning the UltraFab 3002 which does allow this? Yeah, I know a few respondents mocked the advantage of being able to rotate the head but it really can be an advantage when the TV tailgate hits the tongue jack head.
LarryJM wrote:
Don't you love it when someone asks for help, then gets sage advice which they seem to ignore only to come back later complaining that what they chose didn't work:h.
The reason I responded to the OP's query in their original discussion is because I've had this same problem myself but managed to solve it with an UltraFab 3002. However, I suspect that many, including the OP, may not appreciate just how different these tongue jacks can be - not only can the head often not be rotated a full 180 degrees but sometimes not at all. Of even greater importance though is the size and shape of the head ... with many, rotating the head may still not solve the problem because the front of the head isn't that much offset from the rear AND because it's so darned big, sometimes so big that even if you could rotate it the head would interfere with something else one the tongue, such as propane tanks. The UltraFab 3002 is considerably different - fully rotatable 180 degrees, relatively small head, and the front of the head is really offset compared to the rear - which is why I mentioned it in the first place and even provided links to pics of this particular TJ. Of course I can't guarantee an UF 3002 would solve the OP's problem as the trailer / TV relationship is different in each case, as is what else is mounted on the tongue, but of any electric tongue jacks I've seen this particular model IMO offers the best chances of a solution.
44,068 PostsLatest Activity: Jun 10, 2026
