adamstee's avatar
adamstee
Tow capabilities
My 2009 GMG Yukon XL Denali (with factory tow package) is rated for 7900 lbs.
If I adhere to weight restrictions and weight distribution upgrades, can I safely tow a trailer with a 7,038 lbs. dry weight? Thanks
  • OK you have 860 lbs total available.
    Now add,,,,,
    Weight dist Hitch*********************100 lbs
    2 tanks and propane********************80 lbs
    a group 27 battery*********************40 lbs
    you now have 640 left, on tow capacity and have added no food, clothing, lawn chairs, nothing, not even enough water to flush the toilet.
    Light packers tend to have close to 1000 lbs in a trailer, most end up higher, a few very cautious ones get by with less.
    And dont even begin to consider kids and their friends stuff.
    Also check your cargo capacity on the Yukon, at an 8000 lb trailer, you will be around 1200 pounds on the hitch, which counts against your payload, also anyone else travelling with you and all of the cargo in the back count toward that number, is it ok there?
    Happy motorin
  • Safely, yes. Provided your Yukon is well maintained, has good tires and brakes, the trailer is well maintained, has good tires and brakes, the WD system is properly setup and rated to support the actual weight of the trailer.
    It will not, however, be within the weight ratings of the Yukon if that is important to you. You will exceed one or more of the ratings of the Yukon, be that axle, GVWR, GCWR or receiver hitch rating.
    Dry weight means empty trailer, nothing in it or on it. That means no propane or batteries, no water, nothing. Possibly not even an air conditioner or other optional equipment. Time all is said and done you will end up adding at least 1000-1500lbs to the weight of the trailer by the time you fill everything up and pack for camping.
    Most importantly you will probably not be happy with the performance and handling. It will be slow and sluggish compared to the tow vehicle by itself.
