valhalla360's avatar
valhalla360
Navigator
Dec 01, 2020
Tow Haul Mode
I realize Tow Haul Mode isn't new but only recently got experience with it and figured I would share some thoughts.
We've had the truck (2008 F250 V10) for 3 years but life only allowed for some local trips in relatively flat areas and I never remembered turn it on. This year we can't get out of the country for the winter, so we loaded up and headed west.
On flat roads and accelerating, I'm kind of indifferent to it holding the gears a little longer. Doesn't really impact the driving experience much.
What surprised me is the downshifting when coming to a stop and semi-automatic downshifting on hills (tap the brake and it downshifts). At first, I just heard a whining coming to a stop light and until I caught on the truck was downshifting to help slow down, I thought something was wrong.
This truck really holds speed nicely on steep down grades. We've had several 6-7% downgrades of several miles this fall and almost never have to touch the brakes (RPM never going much over 3000 or making any really noticeable noise).
I drove my Dad's trailer out to Phoenix for them a couple times and coming down out of Flagstaff, you had to pay attention. It was a 3/4 ton dodge van with a 360 and even downshifting, you really had to work the brakes to keep speed from getting out of control and the engine was screaming if you let the speed get too high.
Then our first truck was a 1992 F250 with the 7.3 diesel (but before they added turbo). Generally loved the engine but it did almost nothing to help out on downgrades.
Then I found myself playing with it in some of the national parks not towing. Lots of steep switchback roads where you want to go 20-40mph. Following cars that are riding the brakes pretty much for miles and one tap and it downshifts and just strolls along without having to touch the brakes but when you hit a straight section, no need to touch the gear shift, just give it some gas and she shifts to a higher gear.
I haven't had a diesel with the newer exhaust brakes but this truck really does such a nice job downhill, I can't see having a need. Mind you we are pulling a 7500lb trailer so up hill is no issue even with some altitude thinning the air out.
Hope people find this useful.
  • I use it when not towing in stop and go traffic. It really helps slow you down quicker and keeps you from having to apply the brakes at all in some cases.
  • Can confirm that this is how Tow-Haul works on my E-450 Class C
    It holds low gear longer when accelerating, probably not that useful for flat roads (and I usually don't turn it on for the flats), but it really shines in hills. It downshifts sooner on uphills, but the real benefit is on the downhills where it downshifts to maintain speed with engine braking, I've never needed to downshift manually when using tow-haul mode.
  • On my 2020 chevy as soon as I plug in to the 7 pin it reminds you to enguage tow haul mode. TbH dont remember if i used it all the time on the 2012 sierra.
  • I engage tow/haul as soon as I hook up the 5er no matter the distance, speed, or terrain. And I use tow/haul descending some steep winding grades even without the trailer behind. Less need to use the brakes.
