Flashman wrote:
transamz9 wrote:
Flashman wrote:
Lynnmor wrote:
Whatever floats you boat, but asking a transmission to operate at 1200 RPM while towing a load is what the engineers consider abuse and installed tow/haul mode for those that care.
Maybe I should have stayed with a manual tranny. They don't care what rpm the engine is running.
Neither does the auto really. I have the same running gear as you and I see zero difference in fuel mileage between 5th and 6th towing. I toe 20k with mine.
Ah Hah! A self confessed weight criminal. If you have the 342 rear end you are only supposed to Tow 18,000 lbs. (I think)
The Shame.
Actually according to Ram is like 16,XXX but who's counting. Also 99% of the time it's pulling closer to 21K I was just rounding off.
I tow a heavy boat behind my 5th wheel.
With the Aisin and 3.42's on tall rubber 65 mph is the magic number with TH turned on. When running on highway with rolling terrain I lock it in 5th unless I'm running traffic running 70+. 55 is the number between 4th and 5th. It likes to shift @ 2k.
