LAJMINNIEPLUS wrote:
You should be able to tow right up to the limit, BUT, you will probably meet or exceed your tv max payload or gawr long before you reach the tow limit. I have been getting a little frustrated the last few days researching my next tv. Many trucks are advertised to haul huge loads, but the payload is low, so it would be exceeded very quickly with tongue weight, fuel, passengers, etc. Looked at a Silverado 2500 Duramax today and payload was only 2260#. Advertised to pull a 13,000# load!
No problem, 10% HW is 1300 lbs, leaves you with 900 lbs or so for people etc. On the other hand, if you need 25%.......potentially over loaded payload wise if you care about the door sticker. If you care about payload as the sum of the axel ratings, less tare. You probably have another 1300 lbs or so to work with! So the 25% HW 5w at 13000 lbs is doable. I will not recomend it.....but doable! Legally from the LEO, DOT etc, you can go to 80K lbs gcw with this 2500 dmax! If you have enough paid for tonnage, enough tire width so you are under the designed point load of the road bed itself.
marty
