Tow rig is Ford Excursion 7.3. Trailer is 35' long about 9,000 lbs. I'm interested in the best tire for towing, for example a stiff sidewall to limit flex. After doing a little research it see...
Ya well I used.......nvm. You only have 5000lbs on the rear axle. Not sure how much stiffer you need. Any decent load e tire is fine. Worry less about sidewall stiffness and more about suspension stiffness with that big a trailer sitting on the back of an already heavy suv.
