mrekimExplorerAug 09, 2016Tow Rig TiresTow rig is Ford Excursion 7.3. Trailer is 35' long about 9,000 lbs. I'm interested in the best tire for towing, for example a stiff sidewall to limit flex. After doing a little research it see...Show More
97chevorExplorerAug 09, 2016You might not like the R500. Need alot of weight to keep the tires from spinning on wet pavement. They do last though. I have always been able to get fresh tires. Try tire rack.com.
