jefe_4x4
Jun 19, 2018Explorer
Being a recovering hard core off roader, I can offer you, from my experience what to do here.
1. The first thing you should do is have anchor points on your truck, front and rear that can take at least a 20k pull. These are sadly missing on many of our trucks. This is similar to gauging the strength of your winch capacity: 1.5 times the weight of your rig at a minimum. If you don't currently have anchor points, install them front and rear. I use a 3/4 inch, 20K loop (use no hooks), or my 16 ton Pintel (with safety pin) that goes into the rear Class V hitch. On the front, I've welded a pair of 26K pound cement mixer D rings. I also have a class V, 2 inch receiver hitch assy. welded to the Warn Winch bumper, just in case.
2. The strap should match and exceed the weight and pull rating of your vehicle times two. This means for virtually all of us over weight camper types a 30K pound strap with loop ends.
3. Chains are heavy to carry and cumbersome to use (and can be dangerous if they snap) if you try to match them to the load capacity to your truck camper.
4. I carry a variety of D rings with screw in bolts that can be used in a variety of situations. Also, i carry a 5 inch I.D. recovery hook with a safety catch that hooks onto my winch hook (also with safety catch) that will fit around most truck front axles or suspension parts in case the pull-ee has no tow hooks. The spring loaded safety latches are essential. I use no open ended hardware or just looping the tow strap over a ball hitch when trying to move a large heavy vehicle from its snare.
5. A heavy duty "Tree Saver"; essentially a short strap with loops on each end used by jeepers to save trees during winching and recovery operations.
6. A 1/2 inch logging cable called "cat choker". It has hardware that cinches up tight around logs that are to be dragged by a Caterpillar tractor. It will surround and secure just about any vehicle under part, no matter how large or small and doesn't weigh a lot.
7. sturdy cowhide gloves that can take abuse.
The final admonition is to work slowly and methodocally when trying to recover, unstick, or tow a vehicle of our size.
jefe
jefe
