Trail-Mate
Jul 23, 2013Explorer
You should have gotten it with the Tow package because they are usually more then receiver and the sway control was most likely an electronic stability control not any weight distribution stuff. What is your vehicles tow rating without the factory tow package?? It may not be the numbers you posted. Things usually installed with tow packages also include extra cooling ( Larger Radiator ) and trans coolers and might have had a different axle gearing.
