mangchibike wrote:
I'm planning to get rv(tt) life and would need some of your experience opinion.
Tow vehicle
2013 nissan amarda SL 4WD
Dry wight: 5600 GVWR: 7150 CVWR: 15100 MAX TOW: 9000 MAX TONGUE: 910
T.T
2013 Keystone Passport 2910BH
Shipping weight: 5354 Carrying capacity: 1846 Hitch: 725
1. Am i safe to tow? and should i buy class IV hitch from nissan dealer or T.T dealer?
2. Any additional tow item i need like sway control, equillizer?
3. I'm planning to dry camp would need generator, which one should i buy, honda generator (if it is what size)or spcially made for R.V generator (less noise,, i heard and where i can get it)?
Thank you in advance
The trailer has a heavy tongue as shipped. If you can load the trailer while not adding much more tongue weight, you're golden.
Assuming you add 1,00lbs of stuff in the trailer (thats a LOT of stuff) you'll be at 6300lbs and your tongue should not be less than 630lbs. Starting out with a 725lb tongue, I again think you're in good shape.
I would have a hard time choosing an aftermarket hitch if there is one designed and specially fitted to your SUV. If its not specially fitted, then save money and buy aftermarket.
You will absolutely need a WDH. Many like the E2 Equalizer, I sure do!
Honda generators cannot be beat. Yamaha is a close second. And there are many others if money is tight, but you'll have a little more noise and power many not be as "clean".
