Cardinals wrote:
Yes. my axle is 3.73 and thus my question to the group. They have included "dual sway cam" as part of purchase.
If that means a Reese dual cam WDH, keep in mind that they take a bit more fiddling to install and in some cases, a while to tweak them to optimize the performance. Excellent WDH. Do NOT let the dealer install it tho. Read the sticky in the towing section and learn how to do it yourself. With that high a tongue wt., there are some important considerations to know about. You can use the WDH without the cam arms installed to get the TT home. Make sure the dual cam WDH has the correct rating including the spring bars and the heavier duty snap-up brackets.
I would suggest going to a scale with the truck and getting an accurate wt. and use the GVWR on the door pillar sticker to give you the actual payload capacity. Actual payload capacities can vary a little or sometimes a lot from the figure on the sticker.
