- Single alternator has plenty of amps. The trick is getting the proper voltage on the battery that needs charging. A DC-DC charger will work excellent for this purpose. Still takes 3 to 5 hours to get a flooded battery from low on charge to 95%+.
https://www.renogy.com/12v-dc-to-dc-on-board-battery-charger/
Also consider some solar. This works all day with no effort. Works in motion or stationary. Does need sun of course. 200 to 400 watts works well for most people. Even if it does not provide all the power solar will significantly reduce generator or alternator run time. - jdc1Explorer IIDual alternator. Best you could ever do. Some super duties come equipped that way.
- pianotunaNomad IIIdc to DC voltage boosting may be the best way to improve charging.
- theoldwizard1Explorer II
Seon wrote:
As a backup I carry a 12v charger powered by a 2K generator.
The 12VDC output on most of today's generators does a poor job of recharging a lead acid battery. You are better off plugging in a AC battery charger. - theoldwizard1Explorer II
old idaho guy wrote:
If you are trying to charge your battery while camping, use jumper cables from battery to battery
A DC-DC charger will do it faster because of what I just described. - theoldwizard1Explorer II
blaczero wrote:
How slow is it? Is there a mod you can do to make it charge quicker?
The real issue is how large is your battery bank and how depleted is it (what is its "state of charge" SOC ?)
Sometime around 2000, the entire auto industry switched to "smart charging". Smart charging is when the PCM controls the output voltage to the alternator to limit the voltage to "just enough" to replenish the battery after a start and not left the voltage go so low as to discharge the starting battery.
This means that about 5-10 minutes after starting you vehicle the output of the alternator is about 13.2V-13.4V and there is not much you can do about that !
So if your RV battery is at the end of 25' of wire (actually double that because you have a ground connection) you will be darn lucky to get 13.0V, probably less. You can NOT charge a lead acid battery on that little voltage. USING HUGE WIRING FROM THE VEHICLE BATTERY TO THE RV BATTERY DOES NOT SOLVE THIS PROBLEM !
The only solution is a DC-DC battery charger mounted close to the RV battery. Most can accept voltages as low as 10V-11V and boost them up to the proper voltage (>14V) to charge a battery. - SeonExplorer III bought from Amazon a 20watt solar panel charger/maintainer connected to battery #1 while the trailer powers off #2 battery then next day switch to #1 battery and transfer the solar connectors to #2 battery to charge.
Works for me. - LwiddisExplorer IIWhat’s for lunch, wanderingbob?
- old_idaho_guyExplorerIf you are trying to charge your battery while camping, use jumper cables from battery to battery
Bigger cables on a dedicated charge line.
This is how I did it
My truck has dual alternators
44,051 PostsLatest Activity: Oct 02, 2025
