downtheroad wrote:
PAYLOAD is just if not more important. Make sure that once your tow vehicle is trip ready loaded with gear, passengers, the dog, whatever - make sure it has enough payload left over for the hitch and tongue weight of your loaded trailer...
Confused???
It took me 3 tow vehicles to get it right.... because I listened to the dealer and only looked at tow ratings...:S
(I'm a slow learner, but I had fun shopping for vehicles)
Me too !!!
That, and I got into trouble, every time I went to an RV show.
Payload --- That's your capacity to carry XXXX lbs without exceeding your GVWR. It gets eaten up by weight of cargo, people, aftermarket accessories, WD hitch, and trailer tongue weight.
Tow capacity is what it's rated to pull -- In theory, the vehicle can pull it's max tow capacity, if the driver weighs 150 lbs, he has no cargo , and he has no passengers. Max tow capacity is also reduced by weights affecting your payload.
Example:
If the vehicle has 1200 lbs payload and 8000 lb tow capacity, and you add 800 lbs of people and cargo. The available payload is down to 400 lbs, and max tow capacity is 7200 lbs.
Average tongue weight of 7200 lb trailer would be around 900 lbs. That would be a problem with only 400 lbs of payload available.
It's not uncommon to run out of payload, before you reach that max tow number.
Calculate your payload requirements and see how they match up with the tow vehicle.
