LarryJM wrote:
transamz9 wrote:
LarryJM wrote:
The real answer which no one has mentioned IMO is that the vehicle must pass stringent braking standards such as fade, temps, etc. based on a specific number which is the GVWR and it would be cost prohibitive to have all the various GVWRs certified so you will generally find one class of vehicle with a specified GVWR and then for different axle and tire options and even some suspension options you will get various axle wt. ratings whose sum often don't equal the GVWR for that vehicle. A good example is my Van where with the diesel engine there is an option for what is called "ONE UP FAWR" which increases the FAWR 200lbs, but has zero change to the vehicles GVWR.
Larry
That's weird because a lot of 250/2500's have the exact same brakes as the 350/3500.:h
Doesn't matter since both undergo separate independent brake testing so each have a separate certification for that class vehicle. If they have the same braking system it just means the lower GVWR preforms better than the higher GVWR, but both meet or exceed the required performance standards. It is totally up to the manufacturer to specify what the GVWR is as long as it is less than or equal to the sum of the two lowest GAWRs for all the potential factory option combinations.
One thing I'm not sure of is how they handle the various tire options within a class of vehicle as far as testing goes.
Larry
Well if they need to test each different GVWR, then Ford needed to test and certify a slew of F150's!!!
Look at the payload tab of this document. For the 4X2 reg cab I counted 5 different GVWR, looks like 6 for the Super cab 4X2.
F150 GVWRWhen my 01 was built Dodge didn't change the VIN to reflect that I had 265/75 - 16 RE tires, the Vin still shows 245/75-16 RE. They are part of the Camper package on the 2500, that rear sway bar and 3500 springs.
