milo's avatar
milo
Explorer II
Dec 22, 2013
Tow Vehicle GARS vs GVWR
Good Evening; 1st off I've searched thru any & all threads I thought this might be in, but no such luck. Why is that the gross axle weight ratings on most tow vehicles, when added together, are greater than the gross vehicle weight rating. Example my F-150 FAWR 4050, RAWR 4800 = 8850 and the GVWR is 8200. I guess I'm not smart enough to understand. So ... please enlighten me as to why these numbers are this way and do not equal each other. But I suspect the 650 lb difference is a cushion but I've been known to be wrong.
be nice please
Milo
  • Because even if you managed to load the vehicle perfectly with the payload centered over both axles, the weight on the axles would shift the moment you turned the key and pulled out of the driveway. Every time you brake the vehicle's momentum will throw additional weight onto the front axle. That is why the nose dips when you brake hard. Every time you corner you are throwing additional weight onto the outside wheels. And if you are accelerating or climbing a steep incline you are shifting weight onto the rear axle.
  • My MDT is that way, GVWR is the sum of the axel wt ratings! most rigs over a DOT class 5 truck ARE that way, Only in light duty and some class 4 rigs is the sum greater than the actual.
    Depending upon the state or canadian provence you are in, the sum or lower number may be the actual law. In Washington, non of them matter, it is how much you have a paid for license for. The minimum is the next highest ton at 1.5 times the tare. You can only buy registration tonnage tags by the ton. SO for the ops rig, a 6 or 8k license for the truck. He would be legal for one of those numbers, He could also buy a 10K plate, and be legal to that number too.
    My 18200 navistar is licensed at 26K, been pulled over at just over 27K, no overwt tickets so far. As they give my 600 lbs per inch width of tire! WELL OVER that door sticker which is in my office! My now sold 05 dually, was licensed at 14K, no issues going thru scales either.
    Not sure truly why the sum of the axels is greater than the gvwr.......probably as said, so idjiots can load it up incorrect, and still be under the warranty equal numbers.........
    Marty
  • GVWR is the MAX weight the 'whole' package can be----tires, suspension, braking power, frame, axle etc.
    The axle ratings are what that axle can handle.
    The 'parts' are stronger than the 'whole'
