Indy317 wrote:
LeBout,
Thanks for your reply. My tow vehicle has a towing pkg with tranny cooler, 3.73 rear axle, trailer brake controller, and sway control. We're pulling a trailer similar in size to what is in your pic above. Are there any other things you do to improve your towing on grade?
Nope! We have identical pickups in terms of gear ratio, tranny and engine. My TT is 5440 dry and probably close to 6,500 loaded. We're rated for 9,200 lbs, so you will be comfortably within your towing range if you're comparable in weight.
Contrary to what another poster in this thread wrote, I have NOT found State and County highways to have steeper grades than on the freeway. At least not through Wyoming. In fact, I have found them significantly easier to navigate.
The pickup definitely slows down on very steep climbs, and I found the best way to handle it was to be patient and not get in too big of a hurry. I always pull with my "OD OFF" setting engaged, which keeps your RPMs between 2200 and 2500 for most level grades. I would allow the pickup to increase to 3000 RPMs (or a little higher) when going uphill. (The Cruise Control wants to shift down and go to 4000 RPMs but I would over-ride the cruise and keep it lower. Years ago I blew an exhaust manifold gasket by allowing the engine to rev too high on hills and I don't want to repeat that mistake.)
I felt the F-150 performed admirably and did a fine job. Yes, my diesel brothers with TTs and 5ers were passing me on the hills, but that's really not a fair comparison, and I decided ahead of time not to let it bother me. :)
So my advice for traveling out West with your F-150 are:
1. Take your time and don't push your TV too hard, and
2. Consider getting off the freeway (Interstate) as it just promotes a slower, more relaxed approach to hauling a TT PLUS I found the inclines less steep.
Oh...and consider wind speed and direction. It DRASTICALLY affects towing capability and fuel mileage. Most of the time it can't be helped, but if you don't have to travel on a day when you would be bucking the wind or dealing with a strong side wind...DON'T. (Some of the Western states, like Wyoming and Montana are famous for their high wind areas.)
