Texas51's avatar
Texas51
Tow Vehicle Nissan Armada
Hi everyone,
I have decided to get a travel trailer. I have I have a two year plan. Buy a tow vehicle early 2019 and the following year the trailer. I am considering the 2018 or 2019 Nissan Armada. I need a SUV with three rows and don't want to spend 60,000 on a expedition (I don't like them either) or the Tahoe. The Armada has a tow capacity of 8,500lbs. The bunk models I like are in the 3,500 - 5,000lbs 20ft-28ft. Does this seem like a safe setup? Would you recommend additional cooling? Anyone here have a similar setup?
I know buy a Doge Ram 3500 or 7ton truck that's my best bet but I really do not want a pickup.
  • I looked at Armadas earlier this year and didn’t like them. The interior felt cheap and already had parts loose.
    It can do the job, I am sure. I’d just want some more wheelbase and some more payload.
    Thanks!
    Jeremiah
  • The Armadas payload is between 1500 to just over 1700 pounds before any options are included, no passengers or cargo. As Jebby14 noted, it will probably be tourlimiting factor.
    That being said, I towed a 3500# tt for years with a mid sized suv and never had an issue. I was probably right at the payload. It was a much shorter trailer, though, with a 17’ box.
    I would look at the Armada, paying close attention to the payload on the individual vehicles. When you shop for the trailer, understand your limitations.
    Btw, I upgraded to a pickup and am amazed by the towing difference. While a pickup is still not my first choice, and I miss my suv, it’s hard to argue with their capabilities.
  • payload (look in door for it, towing capacity means nothing) - weight of everybody/everything in the car - 80-100 lbs for a weight distributing hitch = whats left for tongue weight.
    Loaded trailer weight (not dry weight this number also means nothing) x 0.15 = tongue weight. I suspect you are going to be over payload but you need to run the numbers. good luck.
