Hanna's avatar
Hanna
Tow vehicle question.
I have an 04 Durango limited, it has the hemi and 3.55 gears, and factory tow hitch. Towing max is 7200 lbs. my wife has her heat set on a coachman apex 288BHS. The trailer weighs 4,842 lbs dry and has a gross weight of 7,000lbs. The trailers is 31.2 ft long. The length is my main concern. I will be using the equalizer hitch with 4 point sway control. The question is does anyone think I shouldn't tow this trailer? Will be mostly flat land and maybe 3 hours max travel time.
Coachman 288BHS
  • Thought it was a little to big for the Durango, she wants that trailer so guess we will look for a different tow vehicle, will do mor research on it.
  • So if I have researched this correctly this is what I got.
    04 Durango hemi limited with 3.55 gears
    GCWR = 12,500
    GVWR = 6,600 (5079 for truck and fluids and all options)(1520 for people and cargo)
    So 12,500 - 6,600 = 5,900 for trailer and stuff packed in the trailer.
    Apex trailer has base weight of 4,842 dry no gas or water. GVWR is 7,000 lbs.
    7,000 - 5,900 left for towing = 1,100 over my GCWR.
    04 Durango hemi limited with 3.92 gears
    GVWR = 14,000
    So 14,000 -6600 = 7,400 for trailer and stuff packed in the trailer.
    7,000 - 7,400 left for towing = 400 less then the 14,000 GCWR.
    So if I swap out to the 3.92 gears I should be fine except for maybe length. Durango only has 40 k miles on it would hate to have to trade it in.
    Please let know if I didn't under stand what I'm talking about please.
  • Why do people say , The wheel base on the durango is to short to tow anything more then a 24 ft. TT. Then say its fine on an expedition with the same wheel base. Is it because the expedition is heavier then the Durango? Not trying to argue or be a smart tail just wondering.
  • I may have been associating your durango with the newer ones, which are pretty small. a 2004 is a fairly large suv. maybe you would be ok. It would just stink if you felt uncomfortable managing it. You will pull it fine. The worry comes with stopping and managing sway. You could probably go longer than 23-24 feet, but 31 might be pushing it. I don't see too many durangos at campgrounds. See more tahoes, suburbans and expeditions/excursions and of course trucks. You have too look at the numbers and figure it out. Dealers will almost always tell you it's fine when it may be pushing it. I'm sure a good sway system will help.
    GCWR = 12,500
    GVWR = 14,000
    You need to make sure you understand what these numbers are telling you. You're not using them correctly. GVWR and GCWR are two separate things, and neither address a couple other important considerations.
    Let's first look at GCWR since it's the easiest one to satisfy. GCWR is Gross Combined Weight Rating. It's the maximum amount of weight the vehicle should be expected to pull. Assuming the trailer weighs 7000 and the SUV weighs 6600, that's GCW=13600 against a GCWR=12500. So with your SUV as-is, you're well over GCWR. If you do a gear swap, your GCWR=14000, and you're under by only 400. No matter how you look at it, you're really pushing this limit.
    Another consideration is frontal area. Pulling a travel trailer with a high profile is very different than pulling a cargo trailer. GCWR addresses only weight, but cruising down the highway, aerodynamic drag has a far greater impact than weight on your ability to pull it. Even with a gear swap, that 400# headroom in GCWR is not enough to compensate IMO.
    Now let's look at GVWR, which is Gross Vehicle Weight Rating. This is the maximum amount of weight the vehicle should be expected to carry, and it's almost always the deal-killer for smaller tow vehicles. Yours is only 6600. You quoted 5079 dry weight, but have you taken it to the scales? I doubt it weighs in that light. But even if it does, you've got 1500# left. But you forgot to add in the tongue weight of trailer which is being carried by the SUV's chassis. A properly loaded trailer will have 12-15% of it's weight on the tongue to avoid sway. So when loaded, that trailer will have a tongue weight of close to 1000 pounds! Subtract that from the 1500#, and you've got only 500 left. And don't forget the weight of the hitch itself. 100-150# is about right. What about fuel? Does that weight include a full tank of gas? Probably not. Add another 150# for that. Now you've got only 250-300# left for people and cargo, which just isn't reasonable. Payload goes fast, and this is why GVWR is the biggest limiting factor for SUVs and 1/2 ton trucks.
    Another consideration is wheelbase. A longer wheelbase provides more stability against sway. Longer trailers require trucks with longer wheelbases, plain and simple. Now I'm not one to say you have to limit yourself to 23', but I wouldn't even consider pulling a 31' trailer with only a 119" wheelbase.
    As I see it, your SUV isn't just pushing the limit, it's over the limit in every category.
    -- Rob
  • Thanks for the info. Guess I will just have to get a bigger tow vehicle, just. Hate to get rid of it but I want to be safe in towing the trailer don't want to cause anyone any problems.
  • Always safety first. Do this to have fun not headaches.
