4evertravel wrote:
We recently upgraded our tow vehicle, so now the hitch and ball sit much higher than the coupler on the tongue of the trailer (when its level). After hooking it up and putting all the trailer weight on the tow vehicle, and not the jack, the rear end sags. We have a weight distribution hitch, but that doesn't seem to help. What could cause this, and how do we fix it?
Thanks-
First off, you want to change your WDHitch configuration so its ball sits at the proper level (when unhooked), same height as the trailer tongue when level. Does it have a row of bolt holes that will let you lower the head with the ball?
What brand WD hitch are you using? Different ones have different instructions for proper setup. A measuring tape might be needed.
