the_bear_II
May 08, 2013Explorer
I always use the tire pressure shown on the sidewall of the tire. If properly inflated and rated to carry the load you have you should see very little sidewall bulge when hooked up to your trailer.
A stiffer sidewall usually means a stiffer ride.
You're goal when buying tires is to buy tires rated at least 25% higher than the loads you typically carry. This gives you a safety margin.
