Gdetrailer
Nov 10, 2021Explorer III
StirCrazy wrote:davehultin wrote:
I'm looking to replace the tires on my tow vehicle (2010 Ford Expedition) and I was surprised to learn that my existing tires do NOT match the tires specs on the vehicle placard. I don't know when or why that happenend. Anyways...
Placard specs are P255/70R18
Existing tires are P265/70R18
So my existing tires are 10 cm wider than what's specified. Is that a bad thing? Or just a "thing?"
My Expedition is no champ for gas mileage, but does that extra 10 cm per tire take the mileage down significantly?
In your opinion, should I return to specs when I replace the tires, or is there a compelling reason to stick with the wider tires?
I would put them back to factory size as right now they are taller , but it is only 10 mm not 10 cm so its not a huge deal but your spedomiter will be out a little and you milage wont be accurate. I wouldnt go out of my way to do it but next time you change tires out .. as for fuel milage I have had some cars that didnt care about bigger tires and some that just hated them and gas milage dropped significantly, that was a little more of a change then what you had on an older f150 but I had to go back to the factory size on that one it was so bad.
Steve
I would somewhat agree with the idea to go back to the OEM size specified on the door sticker.
While it looks like there is very little difference, in reality that difference can alter multiple things seen like speedo and mileage readings and things unseen like handling, traction, braking, gear ratio.
Rather than guessing, one can lookup and compare with online tire size calculators.
Like THIS ONE
Select compare, input your OEM tire size and the new tire size and hit calculate..
I have copied a snip of the OPs tires..
The current tire the OP has is .4" wider than stock, has .3" wider sidewall, .5" taller, 1.7" in outside diameter larger and turns 10 revs less per mile.
While that all seems like it isn't much, it does affect (lower) gear ratio which reduces effective HP/tq getting to the ground and will affect the braking a bit.
It affects traction some with the wider width under some circumstances and may add some more turning effort for steering.
The additional sidewall can add more sidewall play which can result in feeling a bit more squirmy which can affect the overall handling than if it had OEM size tires.
There are various valid reasons why it has larger size, price point and availability may have played a big role to the selection.
Less valid reason is "looks", taller tire and larger side walls than OEM sizes looks much cooler to some folks.
I wouldn't replace them right now if they have good tread, just go back to recommended OEM size at next tire change.
44,052 PostsLatest Activity: Oct 14, 2025
