coolmom42
May 20, 2018Explorer II
RTCastillo wrote:bid_time wrote:
Easy fix, you need more tongue weight, 15% is good, more is better.
And some people are saying, load up some water as added weight, while the mpg suffers, adds to stability.
Don't know the conventional wisdom on this since water can swoosh left and right and therefore by itself unstable, lol.
Veteran RVers with more experience that his newbie can provide more sense that I lack.
It depends on where the water tank is. If it's behind the axles, that will make matters worse. It could also increase the weight to the point of overloading the tow vehicle. But if neither one of those applies, it may be an easy way to fix a too-low tongue weight.
