dodge_guy
May 21, 2018Explorer II
First I would ditch the standard WD hitch and go with a Reese Dual Cam. You may be able to add it to your existing WD hitch if the bars have the crook at the ends. Then I would verify you have proper tongue weight, I go with 12%. The wheel base is a bit on the short side, but if you have the all the above set up properly then you should be good to go.
