hookset's avatar
hookset
Tow vehicle too short of wheelbase???
Recently downsized from 39' 5th wheel & one ton diesel dually to a 30' (box-34' inc hitch)trailer and a 2017 Chevy Silverado Tahoe suv. On tow home from dealership & 1st camping trip (100 miles total) I experienced a considerable amount of sway even with a WD hitch and 1 sway bar. Many years ago we started camping with a 30' trailer pulled by a Chevy Blazer - don't remember having this problem. Is it ---
1. Tahoe has too short of a wheelbase (116 inches)
2. Need 2nd sway bar
3. WD hitch not installed correctly
All the above or ????
  • Try tightening the sway bar first.
    I'm a newbie and nowhere being an expert.
    Except that I've experienced a bit of over-reactive sway when a rig passes me by (but nothing I lost control of). I just stop in a nearby gas station and noticed the untightened sway lever and adjusted it. It appeared to have solved it. I tow a 21 trailer with a 4-runner.
  • I would suspect it is a little of all the above but mostly the hitch.
    After pulling a fifth wheel with a dually any sway at all will seem excessive.
    It has been a long time since I pulled a tag-along but the sway when being passed by trucks and the cross winds was why I went to a 5er.
    I was under the impression that they have some hitches now that eliminate all the sway. May need to spend some big bucks but I am certainly not an expert on equalizer hitches.
    Good luck I know how unsettling it is to have that issue with your family on board.
  • My vote is for the hitch not being set up correctly. For some reason, dealers have a hard time with this job.
    I would go over the instructions and increase the tension on the spring bars until you get the best handling. Then you can add friction sway bars.
    You want to keep the sway from starting in the first place rather than control it with friction bars constantly.
    It could also be that your Tahoe is just too lightly sprung for the job but try the above first.
