tcr475 wrote:
Thinking of buying a 20 to 24 tt I have a 08 silverado with a stock 5.3 wondering what upgrades i will need?
For 4 years I towed our 24' KZ Spree which had a GVWR of 6000 lbs and typically weighed ~ 5500 lbs loaded and ready to camp with our 2006 Chevy Silverado with the ubiquitous 5.3L GM engine coupled to a non-tow friendly 3.42 axle ratio via the older wide ratio 4-spd transmission. I then continued to tow that same trailer with a 2005 Avalanche, same engine, same transmission, same axle ratio - same results ... OK but it sure wouldn't set any speeds records, always towed in 3rd with Tow Haul ON, and could only negotiate significant upgrades and maintain a respectable highway speed by downshifting to 2nd. I now tow a shorter trailer weighing 1000 lbs less than the Spree with that same Avalanche and the results aren't all that much different - OK but not spectacular as it's the barn door effect creating so much wind resistance, not overall weight, that has that little 5.3L working. GMs with the newer narrow ratio 6-spd would do better but if the axle ratio isn't at least a tow friendly 3.73 then that 5.3 will still be working. If your particular truck isn't so equipped then changing the axle ratio would by far be the most effective way of improving it's towing capability ... fairly easy and not too costly with a 4x2 but much more $$$$ involved if it's a 4x4. FWIW, I did not install any extra coolers in the Avalanche, deemed unnecessary by my GM dealership as long as the trailer's GVW loaded and ready to camp didn't exceed 6000 lbs. I've been using this Av since 2010 for towing and haven't had any issues at all but I certainly wouldn't want to tow any trailer with a GVW exceeding 6000 lbs.
