jumprope's avatar
jumprope
Tow vehicle
I am planning on purchasing a tt with a dry weight of 5500 lbs. I am also looking for a used half ton truck between years 2004 and 2008. I am considering a 2006 dodge ram 1500 Laramie with a 5.7litre v8 engine. Will that pull potentially 7000lb comfortably or will it be a strain? I'm trying to avoid a 3/4 ton but I'm not sure what I should be looking at in the way of a half-ton. I could use some advice. Thank you
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to "posting" issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
