I tow a 2017 KZ Sportsmen Classic 180bh with a  2006 Kia Sedona EX minivan.  The 180bh dry weight is 2700.My minivan tows it easily. Before I purchased my travel trailer, I did a test tow of a travel trailer that weighed 300lbs more than the one I purchased. I would not purchase a travel trailer without a test tow.  I then had the largest transmission cooler that would fit installed. Do not rely on just the cooler that came with your vehicle.  I  then had Timbren suspension installed on my rear tires. I had an E2 weight distribution hitch put on. It has a built in sway control and doesn't have to be adjusted to back up. You will also need a brake controller. My hitch sits very low as well.  The dealer assured me that it shouldn't be a problem and it hasn't been.  Surprisingly, my gas mileage is great while towing.  I only use 1/4 a tank more when towing. I usually get around 21mpg so when towing,I am still getting around 18 Mpg. Kia minivans are one of the best rated for towing so please don't do anything until you have a test tow with your vehicle.
