stumper92 wrote:
mkirsch wrote:
If your "application" wasn't such a secret, maybe someone could give you some insight that would help.
No secret... 2011 Ford Fiesta. Also would like to setup my 1999 Jeep Cherokee. Although with the Cherokee I thought about just making an adapter that fits in the receiver with lights mounted on it. Then I could run the wire under the Jeep with a plug at each end for connecting to the tow rig at one end and the lights at the other.
the kits come with all the wiring you need, the correct connectors, even the pig tail for the front of the toed. I can't build them for the price they charge for the kit does not require cut wires or crimps into wire harness. Long term best solution.
