memtb wrote:
4x4ord wrote:
I consider an 18000 lb trailer a light trailer even though most rv's are lighter than that. I tow much heavier than 18000 lbs with my SRW. If I didn't feel safe doing it I would use a bigger truck.....I've got lots of trucks. I think the 3500 GMCs are is rated for 17600 lbs. Alot of dually guys haven't hauled with a new style SRW pickup. Pulling my 16000 lb rv with my SRW is a very relaxing experience.
X2!!
I’m sure that a DRW, could/would be slightly more stable/ comfortable when towing, but....for those of us that “do not” have a dedicated tow rig, the SRW is more practical for daily use. Especially....if daily use includes off-road use, and/or snow and ice! JMO
On a new truck, your axle rating will likely be more than adequate. But...you should consider upgrading tires/rims for the pin weight of the unit. We have Rickson Wheels 5000 load rated...each) and 19.5” tires (4800 lb rating...each). As a side note....we’re running Hankook DH07 245/70R/19.5. They are “very” slightly taller than our stock tires, giving us a two(2) mph error at 60 mph!
They work well for highway use, and have good off-road traction (mud and snow). Very quiet when “not” towing, but get a little “whine” under load. The “whine” is minor, and doesn’t give us issue.
Any of the new trucks have plenty of power to tow your trailer, but the pin weight is what will limit you in a SRW. If you already had a reliable SRW, I would point you toward wheel and suspension upgrades but don't really think I would buy a truck knowing it immediately needed upgrades to do the job.
You drove a DRW and know its limitations and its advantages. Are you looking at SRW's strictly due to cost or are there other factors? I expect you would spend $3-5k to upgrade a SRW to handle that FW pin weight.
