Caddywhompus wrote:
Francesca Knowles wrote:
Redsky wrote:
A Subaru wagon will pull a 3,000 lb. trailer and without the trailer it will get 30 MPG on the freeway.
Dunno which "wagon" you're referring to, but I doubt that any Subaru except possibly the Tribeca is capable of towing 3,000 pounds of travel trailer. Limiting factor is tongue weight- limited to 200 pounds on just about every model. You can't tow a 3,000 pound TT safely with such a low tongue-to trailer ratio. The "high" number really only applies to boat towing- due to differences in design those can be towed with a 5-7% ratio.
Again excepting the Tribeca, Subaru max tow limits are between 2,000 and 2700 pounds...And let's keep in mind that the weight of everything in the car except a 175 pound driver has to be taken off that number in order to stay under max GCWR.
This tongue weight limitation is for the Subaru factory hitch, which is only class II. The aftermarket makes class III hitches for most Subarus that can handle higher tongue weights, as well as WD hitches.
That is not correct, though VERY commonly believed. Putting a "higher capacity" hitch on does not raise tow limits on any vehicle. A hitch itself is only one of many design considerations, and the numbers stamped on a receiver reflect only that component's capacity. As for aftermarket W/D, Subaru warns against their use on any/all of its vehicles.
Also, aftermarket hitches are very often inferior to those supplied by the manufacturer- never more true than with that supplied for the Forester. Below is a picture illustrating just ONE major difference. The pic is from a very detailed discussion, complete with illustrations, of an install of a factory hitch on a Forester
at this link. It shows the bumper removed to expose the engineered channels into which part of the factory hitch slides. NO aftermarket hitch supposedly "designed for a Forester" does that.
Furthermore, here quoting from that discussion
Post number 28 wrote:
The OEM hitch connects to the body/frame in 12 places in a design that is engineered specifically to interface with the design of the Forester versus only four connection points (two of which require drilling) for any of the aftermarket hitches that are a standard design. Despite taking a little bit longer to install and roughly $100 more expensive, the superior design of the oem hitch is more than worth it to me. Hitches have the potential to apply extreme forces to the body/frame of your car, and on my car, I would rather have one that has 3X the number of connection points.
None of that, of course, will stop folks from doing just as they please, but as someone who's in the market and having looked at a lot of used cars I can tell you that the effects of using inferior equipment and/or ignoring mfr. limits does show "down the road".
