MBarmer's avatar
MBarmer
Towing 35+ footer
I think i've decided against a 5er due to only having a 2500. I think the payload is going to be too much.
That said, the wife and i have picked out three campers that we really like:
Jayco Jay Flight 33RBTS
Jayco Eagle 324BHTS
GD Reflection 308BHTS
all of these campers are around 1000 lb tongue wt. and 10-11K GVWR
the problem is they are all 36-37 ft long.
How are those going to pull behind a RAM 2500 CCSWB 4x4 6.7?
  • Expect more like 1400 pounds of loaded TW for all of those options. With a properly sized and adjusted WDH with integrated sway control, I cannot imagine having any problems towing comfortably with that truck.
  • I pull a Jayco 28BHS now, which is about 31 ft long. Ive never had any issues even with the EZ Lift WD hitch.
    Is there going to be that much difference for just 6-7 more feet and 3000 lbs?
    I would upgrade WDH for sure.
    Oh, and i do have jake brakes. Emissions still in tact though.
  • Buy a good hitch like a Reese Dual Cam or.... and enjoy the new trailer. I pull a 37ft trailer with no problems with my GM 2500 HD. I also think there will be closer to 1,400 lbs tongue weight when loaded for use.
  • That's a lot of trailer but would think your 2500 would be capable. Do want to point out that no way will those be 1000lbs tongue weight. Count on about 13% tongue weight of the total loaded trailer for a properly loaded TT.
  • They are going to be heavy with a lot of wind resistance. You will be better off with some bolt on parts and a jake brake. Stay on the interstates and better state highways. Your road choices will have a lot to do with your ease of towing.
