popupcamping
Jul 28, 2013Explorer
Deano77 wrote:
To popupcamping.
HW277....yes high wall. Yes I called it TT at first because I am new and thought that meant tent trailer.
The dry weight is right around 3000, total is 3800. Tongue weight I believe is around 250. Both TVs have a tow package of 5,000 lb rating. Seemed like this gives me a 20 % cushion, no? Was also wondering about the FWD, AWD and 4 WD options. It sounds like rear 2WD is best, followed by AWD, FWD and 4WD....but not sure. Any thoughts? And it sounded like you thought this would barely be passable....can you tell me why?
Drive train will not make any difference in towing...FWD,AWD,4WD. Get what you prefer the other 95 percent of the time you will not be towing.
TW is actually 359 lbs dry and will be close to if not over 500 ready to camp. Any less than 450 you will be into a dangerous sway situation guaranteed. Your vehicle will have a max TW allowance of 500lbs so you are MAX MAX with a HW277. The other factor that will be close is payload but you should be fine.
The 3800 lbs will not be an issue. It may slow down a bit on the hills but still unlikely. I have the same 3.5 in my rav4 and it is quite stout. I lose no speed whatsoever on the biggest hills with my 2400lb popup
The reason I say it is just passable because highwalls are huge.
p.s. no worries about the terminology confusion. TT stands for travel trailer
