Deano77
Aug 01, 2013Explorer
Thanks DCfan....perfect information...yes Flaggstaff and Rockwood models are the same. There are two that are the same size, but the 276 had a tongue weight about 100 lbs less. I really like the one with the outdoor burners and sink (277), but if the weight is an issue, I can always go to the 276. I found the Pathfinder has a little bit longer wheelbase, so am thinking it might be a bit better. That is pretty good mileage you are getting!! Do you have AWD or FWD on the highlander?
