goducks10
Feb 28, 2014Explorer
What PSI are you running in the tires. Should be 45psi in the rear. My 2500 CTD requires 65psi front, the Hemi probably only needs 45psi front. Also throw 6-60lb sand bags in the back. Way, way cheaper than the vasoline treatment you'll need from trading in a 13 on a 14.
I had an F150 with maxtow and a payload of 1857lbs towing a 7300lb TT. TW was 900-950lbs. With 8500lbs your going to be over the 1500 GVW and RAWR.
I had no reserve left in the F150. And no Ram has 1857lbs of payload in crewcab/quadcab config's. You'll be sorry you trade.
44,068 PostsLatest Activity: Jun 17, 2026
