The_Texan
Mar 01, 2014Explorer
Empty Nest, Soon wrote:That is the reason we got the "max tow" NHT package on our 2011 1500. It gave us just under 2000# payload, with a 10,700# tow rating. It has a larger rear, HD 4 wheel disc brakes, a built in brake controller with anti-lock feature and a heavier cooling system for both the engine and transmission. We routinely tow 10K± here in the west and I am very satisfied with the setup. Will be towing the trailer loaded with hay from the Boise area to the Reno area next month and it may come close to exceeding the tow rating, but I am very confident in both the truck and the safety of the tow.zogg wrote:
Thanks for all of the replies.....
I do have the tires set lower...front is 50 and rear is 45 using the low pressure switch on the dash. I do have some back trouble and it still rides prey rough for me. I even tried 35 pounds in all for wheels just to see if that would make a difference, but apparently I am just feeling the suspension, as the ride stayed the same.
Also,I really screwed up by not buying four wheel drive.
I am concerned about the payload but it is just the two of us and all of out stuff is loaded in the trailer. I think the towering weight is ok since the trailer is about 8200 pounds loaded and the half ton rating is just over ten thousand pounds. So, I would be close to the limit on pay load, but as long as I keep things in line I would think it is ok.
I've seen lots of half tons pulling trailers heavier than mine and some even towing fifth wheels....doesn't mean they should, I know.
I'm in a real quandary here and all advice is sure appreciated....thanks
I feel your pain.
I had a 1998 GMC 2500HD as a daily driver until my back started objecting to the rough ride. Carrying capacity was 3600 pounds or more. But with the 6.0 engine, HD 6-speed stick, and 3.73 my towing capacity was only 6500 pounds!
I ordered my present 2011 GMC 1500 with the trailering options. It is rated to tow 10,000 pounds with the engine/transmission/differential combination but the available carrying capacity is only 1440 pounds. :(
The truck tows our current TT fine, but much of an increase in TT size is a concern. Before I spend money on both a new TT and a new TV that will rough up my back again, I'm thinking that the same money could be better spent on a used Class A and keep my current truck as my daily driver.
Obviously, towing ability doesn't mean much if the truck can't carry the tongue weight.
Wayne
44,068 PostsLatest Activity: Jun 17, 2026
