zogg
Mar 09, 2014Explorer
Dayle1 wrote:zogg wrote:
I actually do have the wind issue with my 3/4 ton ram. It says in the wind, and I hate it when big trucks go by on the interstate. First the trailer goes to the right so I have to bear left, then the truck starts to turn into the passing truck so I have to pull it back to the right....
There ha been a couple of times that I was not sure it would come back, especially if being passed by a semi with two trailers....gets scary.
WAIT you have a sway issue with a 3/4 ton and you want to downsize to a lighter truck with softer suspension??? How do you think that will work? You need a better hitch first, either a Hensley or ProPride. Or, switch to a fifth wheel and keep the 3/4 ton. Over 25 years I've towed fivers with 2 different 1/2 ton trucks, a 3/4 ton and now a 1 ton and NEVER felt sway under any road/traffic conditions.
The point I was trying to make is that a 3/4 truck does NOT eliminate the sway from passing trucks....that would not be a reason to upgrade from a half ton. I am definitely not buying a 5th wheel camper as I just sank $40K into my current trailer last summer....and I have owned 5th wheels prior, and they do sway some, but certainly not as much as a TT.
My 3/4 Ram with a hemi is less than 800 pounds heavier than a half ton 4x4, so there is not much more weight stability. The suspension is certainly stiffer in the 3/4 ton, and does offer somewhat more stability. However, the stiffer ride is exactly why I am contemplating a 1/2 ton as a daily driver. If I towed all of the time or went thousands of miles I would certainly keep the 3/4 ton.....but, as I stated, I only tow a few times a year and seldom over 500 miles.
I initially posted the question to see how others are doing with a 1/2 ton and a relatively heavy TT, before I make any switch.
44,068 PostsLatest Activity: Jun 10, 2026
