GWolfe
Aug 02, 2017Explorer
The G8 was made by Holden, an Austrailian auto manufacturer, there the V8 is rated to tow around 3500lbs, the V6 goes up to almost 5000lbs.
Here is what I found. It is called the Commodore down there, the link mentions a towing kit, probably like a tow package here.
If your brother could actually find a properly rated hitch it might be OK for short close to home trips but without a tranny cooler and extra engine cooling he may be pushing his luck. I used to tow a Coachmen 16B with similar specs as his and it was an easy tow but I had only towed it with half ton pickups.
Good luck to both you and him.
