EstorilM
Aug 03, 2017Explorer
Huntindog wrote:dodge guy wrote:
In fact it has a tranny cooler in the radiator.
Ummm. As far as I know, all auto tranny vehicles have an tranny cooler in the radiator!
It has a serious shortcoming for towing service.
It can only cool down to the temp of the antifreeze!
Towing tranny coolers are in addition to that. They cool by airflow OUTSIDE and before the radiator.
Generally speaking, most newer high-performance automatic transmissions will operate at-or-above coolant temperatures. I've had older vehicles with external trans coolers, and all the newer versions of said vehicles (with higher all-around ratings) now have integrated coolers.
Assuming your coolant is a set temperature (ie. obviously regulated by tstat to stay exactly the same) then clearly everything was designed for the trans to operate at the same temp as well.
If you start bumping up coolant temps that's an entirely different issue / system, but generally that's not a problem.
Trans coolers were a big deal in mid-late 90's and early 00's trucks / SUVs etc, but it's quickly becoming cliche now. At least from what I've seen / experienced.
