vindicator's avatar
vindicator
Towing a Travel Trailer
I am new to travel trailers.
I have a 2013 Dodge Ram 1500 with a max tow of 8800lbs and payload of 1600lbs.
I am looking to purchase a Keystone Summerland 2820 which has a shipping weight of 6360lbs, capacity of 2240lbs, and hitch of 690lbs.
Will I have any trouble pulling it?
Thanks for your help....
  • I think you'll be fine. While new trailers are often heavier than their shipping weight clams, they'er certainly not at their GVWR. I don't see anywhere where you'll be beyond anythings specs.
  • I would verify payload on the driver's door Tire and Loading sticker. I haven't seen any 2009+ Rams with actual payload that high.
    Otherwise, you should be okay as long as payload is correct and you won't load too much into the cab and truck bed. Get a WDH with integrated sway control.
  • That TT has a GVWR of 8600 making tongue weight well over 1K, payload will more than likely be exceeded. At over 32' you will definitely need a high quality WD/SC hitch that is properly installed and correctly dialed in. I would guess your 2013 Ram could pull it, but the towing experience will not be an ideal one to say the least.
