Hello all, we have a 2004 suburban 1500(1/2 ton) with the 5.3L engine, 3:73 axle ratio, the factory tow package and about 96,000 miles with a towing capacity of 7400lbs. We are looking to tow a 31' 60...
Where'd you get the 6000lbs from? That sounds pretty light for a 31' TT, especially for a Springdale. If it is close to correct I would guess it is a dry weight and will be much higher once loaded.
My 31' TT is considered a lightweight and is 6400lbs dry, 7600lbs with nearly 1k tongue once loaded.
It'll do it, but not very happily and definitely over loaded.
