Hello all, we have a 2004 suburban 1500(1/2 ton) with the 5.3L engine, 3:73 axle ratio, the factory tow package and about 96,000 miles with a towing capacity of 7400lbs. We are looking to tow a 31' 60...
Overweight getting on or off the ramp 3 miles from your home is the same as being overweight 500 miles away. Neither is safe for your family. Suggest you recheck the weights - 6000# sounds like dry weight. Regardless, you're too close to your max....no wiggle room. I think you either need to keep shopping for a more appropriate RV or start shopping for a beefier tow vehicle. Sorry.
