Sandia_Man
Aug 19, 2013Explorer II
It appears that you have a well thought out towing combo that if properly set-up should deliver comfortable towing results. We tow a 32' rig and have no issues with traveling at posted highway speeds, I often have to remind DW to slowdown as she tends to forget we are towing a nearly 10K pound rig. Take it out on the highway and get it up to speed, properly set-up you should not be experiencing any issues even when passing commercial diesel trucks. If experiencing sway or other issues, WD/SC hitch needs to be dialed in. Many have had their hitches "professionally installed" only to find that their set-up was delivering less than acceptable towing results.
44,066 PostsLatest Activity: May 16, 2026
