eubank
May 20, 2014Explorer
Ah, the data I have from Airstream indicate the following:
1995
EXCELLA 28
Dry weight: 6100
Hitch weight: 620
GVWR: 8200
I have the historical data from Airstream as a PDF file on a server:
http://www.monteverderv.com/weights.pdf
Lynn
1995
EXCELLA 28
Dry weight: 6100
Hitch weight: 620
GVWR: 8200
Lynn
stargirl96 wrote:
We have a 2008 Toyota Tundra double cab V8 with 5.7L. It's rated to pull 10,100 lbs. I know you have to look beyond this tow rating when picking a trailer. We are looking at a 1995 28' Airstream. Dry weight is 8,500 lbs. & tongue weight 650 lbs. Will this work, and how do you figure what you can safely tow in a travel trailer? There will be only 2 medium-sized adult in truck, and we tend to pack light.
