desert captain wrote:
Hello... you do know this is an RV site, right? Travel trailers, fifth wheels, that sort of thing. Now if you just want to argue you might (maybe), be able to get that 1500 to pull a flat bed trailer with 10,000# on it but good luck controlling it. The 1500 is a half ton with limited payload, probably well under 1500#. just because you "can" do something does not mean it is a good idea.
Hello .. yeah I've towed RVs since the '60 and have been a RV.net member since '03. So I understand towing issues and am aware this is a RV forum. If you read my reply above closely I acknowledged that fact about RV folks.
Along with my 5er I pull other trailers also with my trucks. A couple of trailers to make some side money with. I see other members mention they have different trailers also
Luck has nothing to do with the wifes 1500 controlling the 10k bumper pull or even the 12k GN trailer.
Just because you may not have the necessary experience or have (or had) the right 1/2 ton truck towing 11k weights doesn't mean its a bad idea.
